Journal articles
TIE breaking: Tunable Interdomain Egress Selection
Abstract : In a large backbone network, the routers often have multiple egress points they could use to direct traffic toward an external destination. Today's routers select the "closest" egress point, based on the intradomain routing configuration, in a practice known as early-exit or hot-potato routing. In this paper, we argue that hot-potato routing is restrictive, disruptive, and convoluted, and propose an alternative called TIE (Tunable Interdomain Egress selection). TIE is a flexible mechanism that allows routers to select the egress point for each destination prefix based on both the intradomain topology and the goals of the network administrators. In fact, TIE is designed from the start with optimization in mind, to satisfy diverse requirements for traffic engineering and network robustness. We present two example optimization problems that use integer-programming and multicommodity-flow techniques, respectively, to tune the TIE mechanism to satisfy network-wide objectives. Experiments with traffic, topology, and routing data from two backbone networks demonstrate that our solution is both simple (for the routers) and expressive (for the network administrators).
Document type :
Journal articles
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01097561
Contributor : Renata Teixeira Connect in order to contact the contributor
Submitted on : Friday, December 19, 2014 - 7:20:44 PM
Last modification on : Sunday, June 26, 2022 - 9:39:50 AM
Long-term archiving on: : Monday, March 23, 2015 - 6:41:44 PM
File
tie-ton.pdf
Identifiers
Citation
Renata Teixeira, Timothy G. Griffin, Mauricio G. C. Resende, Jennifer Rexford. TIE breaking: Tunable Interdomain Egress Selection. IEEE/ACM Transactions on Networking, IEEE/ACM, 2007, 15 (4), pp.761-774. ⟨10.1145/1095921.1095935⟩. ⟨hal-01097561⟩
Share
Metrics
Record views
34
Files downloads
84
