New interface
Poster communications
FindSources3D - Source Localization Using Rational Approximation on Plane Sections
Abstract : FindSource3D is a new method for EEG source localization based on rational approximation techniques in the complex plane. The method is used in the context of a nested sphere head model, in combination with a cortical mapping procedure. This method was shown to perform perfectly for numerical simulations without noise but its performance with respect to different signal-to-noise ratios, to different number of sources and to real EEG data was not investigated until now. The method is evaluated with data simulations and a real EEG data set.
Complete list of metadata
https://hal.inria.fr/hal-01098108
Contributor : Juliette Leblond Connect in order to contact the contributor
Submitted on : Monday, December 22, 2014 - 6:33:56 PM
Last modification on : Tuesday, October 25, 2022 - 4:22:49 PM
Long-term archiving on: : Monday, March 23, 2015 - 7:46:19 PM
File
OHBM_Poster_FS3D.pdf
Identifiers
  • HAL Id : hal-01098108, version 1
Citation
Todor Jordanov, Jean-Paul Marmorat, Maureen Clerc, Juliette Leblond, Andre Waelkens, et al.. FindSources3D - Source Localization Using Rational Approximation on Plane Sections. Organization Human Brain Mapping, Annual Meeting, Jun 2014, Hamburg, Germany. , Poster listings. ⟨hal-01098108⟩
Share
Metrics
Record views
570
Files downloads
118
