OpenMOLE: a Workflow Engine for Distributed Medical Image Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This works demonstrates how the OpenMOLE platform can provide a straightforward way to distribute heavy workloads generated by medical imaging analysis. OpenMOLE allows its users to benefit from a large set of distributed computing infrastructures such as clusters or com-puting grids, no matter the kind of application they are running. Here we extend the OpenMOLE tools to two new cluster job schedulers: SLURM and Condor. We also contribute to the Yapa pack-aging tool to support the widely spread virtual environment package from the Python programming language. Our test case shows how our developments allow a medical imaging application to be distributed using the OpenMOLE toolkit.
main_frree.pdf (354.79 Ko) Télécharger le fichier
hal-01099220 , version 1 (07-01-2015)
Paternité
  • HAL Id : hal-01099220 , version 1
Jonathan Passerat-Palmbach, Mathieu Leclaire, Romain Reuillon, Zehan Wang, Daniel Rueckert. OpenMOLE: a Workflow Engine for Distributed Medical Image Analysis. International Workshop on High Performance Computing for Biomedical Image Analysis (part of MICCAI 2014), Sep 2014, Boston, United States. ⟨hal-01099220⟩
920 Consultations
375 Téléchargements
