Hemodynamically informed parcellation of cerebral FMRI data - Archive ouverte HAL Access content directly
Conference Papers Year : 2014
(1, 2) , (1) , (1) , (3, 2)
1
2
3
Standard detection of evoked brain activity in functional MRI (fMRI) relies on a fixed and known shape of the impulse response of the neurovascular coupling, namely the hemodynamic response function (HRF). To cope with this issue, the joint detection-estimation (JDE) framework has been proposed. This formalism enables to estimate a HRF per region but for doing so, it assumes a prior brain partition (or parcellation) regarding hemodynamic territories. This partition has to be accurate enough to recover accurate HRF shapes but has also to overcome the detection-estimation issue: the lack of hemodynamics information in the non-active positions. An hemodynamically-based parcellation method is proposed, consisting first of a feature extraction step, followed by a Gaussian Mixture-based parcellation, which considers the injection of the activation levels in the parcellation process, in order to overcome the detection-estimation issue and find the underlying hemodynamics.
icassp14_af_tv_ff_pc.pdf (701.49 Ko) Télécharger le fichier
Dates and versions
hal-01100186 , version 1 (06-01-2015)
hal-01100186 , version 2 (06-01-2015)
Identifiers
Cite
Aina Frau-Pascual, Thomas Vincent, Florence Forbes, Philippe Ciuciu. Hemodynamically informed parcellation of cerebral FMRI data. ICASSP 2014 - 2014 IEEE International Conference on Acoustics, Speech and Signal Processing, May 2014, Florence, Italy. pp.2079-2083, ⟨10.1109/ICASSP.2014.6853965⟩. ⟨hal-01100186v2⟩
627 View
138 Download
Share
