An Axiomatic Memory Model for POWER Multiprocessors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The growing complexity of hardware optimizations employed by multiprocessors leads to subtle distinctions among allowed and dis-allowed behaviors, posing challenges in specifying their memory models formally and accurately, and in understanding and analyzing the behav-ior of concurrent software. This complexity is particularly evident in the IBM R Power Architecture R , for which a faithful specification was pub-lished only in 2011 using an operational style. In this paper we present an equivalent axiomatic specification, which is more abstract and con-cise. Although not officially sanctioned by the vendor, our results indicate that this axiomatic specification provides a reasonable basis for reasoning about current IBM R POWER R multiprocessors. We establish the equiva-lence of the axiomatic and operational specifications using both manual proof and extensive testing. To demonstrate that the constraint-based style of axiomatic specification is more amenable to computer-aided ver-ification, we develop a SAT-based tool for evaluating possible outcomes of multi-threaded test programs, and we show that this tool is signifi-cantly more efficient than a tool based on an operational specification.
cav12.pdf (244.79 Ko) Télécharger le fichier
hal-01100773 , version 1 (07-01-2015)
Sela Mador-Haim, Luc Maranget, Susmit Sarkar, Kayvan Memarian, Jade Alglave, et al.. An Axiomatic Memory Model for POWER Multiprocessors. Computer Aided Verification - 24th International Conference, CAV, ACM, Jul 2012, Berkely, United States. pp.495 - 512, ⟨10.1007/978-3-642-31424-7_36⟩. ⟨hal-01100773⟩
Collections
INRIA INRIA2 ANR
83 Consultations
83 Téléchargements
