An improved recursive graph bipartitioning algorithm for well balanced domain decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nested Dissection has been introduced by A. George and is a well-known and very popular heuristic for sparse matrix ordering to reduce both the fill-in and the operation count during the numerical factorization. Considering now hybrid methods mixing both direct and iterative solvers, obtaining a domain decomposition leading to a good balancing of both the size of domain interiors and the size of interfaces is a key point for load balancing and efficiency in a parallel context. For this purpose, we revisit the algorithm introduced by Lipton, Rose and Tarjan which performed the recursion in a different manner.
article.pdf (900.88 Ko) Télécharger le fichier
hal-01100962 , version 1 (07-01-2015)
Astrid Casadei, Pierre Ramet, Jean Roman. An improved recursive graph bipartitioning algorithm for well balanced domain decomposition. IEEE International Conference on High Performance Computing (HiPC 2014), Dec 2014, Goa, India. pp.1-10, ⟨10.1109/HiPC.2014.7116878⟩. ⟨hal-01100962⟩
Collections
CNRS INRIA INRIA2
134 Consultations
289 Téléchargements
