Performance and energy efficiency of big data applications in cloud environments: A Hadoop case study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Parallel and Distributed Computing Année : 2015
The exponential growth of scientific and business data has resulted in the evolution of the cloud computing environments and the MapReduce parallel programming model. The focus of cloud computing is increased utilization and power savings through consolidation while MapReduce enables large scale data analysis. Hadoop, an open source implementation of MapReduce has gained popularity in the last few years. In this paper, we evaluate Hadoop performance in both the traditional model of collocated data and compute services as well as consider the impact of separating out the services. The separation of data and compute services provides more flexibility in environments where data locality might not have a considerable impact such as virtualized environments and clusters with advanced networks. In this paper, we also conduct an energy efficiency evaluation of Hadoop on physical and virtual clusters in different configurations. Our extensive evaluation shows that: (1) coexisting virtual machines on servers decrease the disk throughput; (2) performance on physical clusters is significantly better than on virtual clusters; (3) performance degradation due to separation of the services depends on the data to compute ratio; (4) application completion progress correlates with the power consumption and power consumption is heavily application specific. Finally, we present a discussion on the implications of using cloud environments for big data analyses.
main (1).pdf (742.94 Ko) Télécharger le fichier
hal-01271141 , version 1 (11-02-2016)
Eugen Feller, Lavanya Ramakrishnan, Christine Morin. Performance and energy efficiency of big data applications in cloud environments: A Hadoop case study. Journal of Parallel and Distributed Computing, 2015, 79-80, pp.80-89. ⟨10.1016/j.jpdc.2015.01.001⟩. ⟨hal-01271141⟩
647 Consultations
836 Téléchargements
