Session Types as Generic Process Types - Archive ouverte HAL Access content directly
Conference Papers Year : 2014
(1) , (2) , (3)
1
2
3
Behavioural type systems ensure more than the usual safety guarantees of static analysis. They are based on the idea of "types-as-processes", providing dedicated type algebras for particular properties, ranging from protocol compatibility to race-freedom, lock-freedom, or even responsiveness. Two successful, although rather different, approaches, are session types and process types. The former allows to specify and verify (distributed) communication protocols using specific type (proof) sys-tems; the latter allows to infer from a system specification a process abstraction on which it is simpler to verify properties, using a generic type (proof) system. What is the relationship between these ap-proaches? Can the generic one subsume the specific one? At what price? And can the former be used as a compiler for the latter? The work presented herein is a step towards answers to such questions. Concretely, we define a stepwise encoding of a π-calculus with sessions and session types (the sys-tem of Gay and Hole [4]) into a π-calculus with process types (the Generic Type System of Igarashi and Kobayashi [6]). We encode session type environments, polarities (which distinguish session channels end-points), and labelled sums. We show forward and reverse operational correspondences for the encodings, as well as typing correspondences. To faithfully encode session subtyping in pro-cess types subtyping, one needs to add to the target language record constructors and new subtyping rules. In conclusion, the programming convenience of session types as protocol abstractions can be combined with the simplicity and power of the π-calculus, taking advantage in particular of the framework provided by the Generic Type System.
1408.1459v1.pdf (157.79 Ko) Télécharger le fichier
Dates and versions
hal-01102349 , version 1 (12-01-2015)
Identifiers
Cite
Simon J. Gay, Nils Gesbert, António Ravara. Session Types as Generic Process Types. Proceedings of the Combined 21st International Workshop on Expressiveness in Concurrency and 11th Workshop on Structural Operational Semantics (EXPRESS/SOS)., Sep 2014, Rome, Italy. pp.94 - 110, ⟨10.4204/EPTCS.160.9⟩. ⟨hal-01102349⟩
235 View
139 Download
Share
