A 3D Model-based Simulation of the Electric Field During Cochlear Stimulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The goal of research is to acquire an accurate description of the electric field inside an implanted cochlea through validated 3D numerical simulations. The simulation process should accommodate different cochlear geometries and stimulation patterns. Results from this simulation tool will be used to design better personalized cochlear implants with less energy consumptions in the future.
Imagerie
Poster_OM2014.pdf (9 Mo) Télécharger le fichier
hal-01103374 , version 1 (14-01-2015)
  • HAL Id : hal-01103374 , version 1
Kai Dang, Maureen Clerc, Jonathan Laudanski. A 3D Model-based Simulation of the Electric Field During Cochlear Stimulation. 8th International Symposium on Objective Measures in Auditory Implants, Oct 2014, Toronto, Canada. ⟨hal-01103374⟩
Collections
INRIA INRIA2
184 Consultations
297 Téléchargements
