New interface
Conference papers
On the behaviors of affine equivalent Sboxes regarding differential and linear attacks
Abstract : This paper investigates the effect of affine transformations of the Sbox on the maximal expected differential probability MEDP and linear potential MELP over two rounds of a substitution-permutation network, when the diffusion layer is linear over the finite field defined by the Sbox alphabet. It is mainly motivated by the fact that the 2-round MEDP and MELP of the AES both increase when the AES Sbox is replaced by the inversion in F 2 8. Most notably, we give new upper bounds on these two quantities which are not invariant under affine equivalence. Moreover, within a given equivalence class, these new bounds are maximal when the considered Sbox is an involution. These results point out that different Sboxes within the same affine equivalence class may lead to different two-round MEDP and MELP. In particular, we exhibit some examples where the basis chosen for defining the isomorphism between F m 2 and F2m affects these values. For Sboxes with some particular properties , including all Sboxes of the form A(x s) as in the AES, we also derive some lower and upper bounds for the 2-round MEDP and MELP which hold for any MDS linear layer.
Document type :
Conference papers
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/hal-01104051
Contributor : Anne Canteaut Connect in order to contact the contributor
Submitted on : Friday, October 20, 2017 - 11:06:45 AM
Last modification on : Friday, January 21, 2022 - 3:13:43 AM
Long-term archiving on: : Sunday, January 21, 2018 - 1:09:42 PM
File
EC2015.pdf
Identifiers
Collections
Citation
Anne Canteaut, Joëlle Roué. On the behaviors of affine equivalent Sboxes regarding differential and linear attacks. Eurocrypt 2015- 34th Annual International Conference on the Theory and Applications of Cryptographic Techniques, Apr 2015, Sofia, Bulgaria. pp.45-74, ⟨10.1007/978-3-662-46800-5_3⟩. ⟨hal-01104051⟩
Share
Metrics
Record views
192
Files downloads
223
