To Infinity... and Beyond!
The traditional method for proving program termination consists in inferring a ranking function. In many cases (i.e. programs with unbounded non-determinism), a single ranking function over natural numbers is not sufficient. Hence, we propose a new abstract domain to automatically infer ranking functions over ordinals. We extend an existing domain for piecewise-defined natural-valued ranking functions to polynomials in ω, where the polynomial coefficients are natural-valued functions of the program variables. The abstract domain is parametric in the choice of the state partitioning inducing the piecewise-definition and the type of functions used as polynomial coefficients. To our knowledge this is the first abstract domain able to reason about ordinals. Handling ordinals leads to a powerful approach for proving termination of imperative programs, which in particular allows us to take a first step in the direction of proving termination under fairness constraints and proving liveness properties of (sequential and) concurrent programs.
Performance et fiabilité [cs.PF]
