Approximating the length of Chinese postman tours - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue 4OR: A Quarterly Journal of Operations Research Année : 2014
This article develops simple and easy-to-use approximation formulae for the length of a Chinese Postman Problem (CPP) optimal tour on directed and undirected strongly connected planar graphs as a function of the number of nodes and the number of arcs for graphs whose nodes are randomly distributed on a unit square area. These approximations, obtained from a multi-linear regression analysis, allow to easily forecast the length of a CPP optimal tour for various practical combinations of number of arcs and nodes ranging, from 10 to 300 nodes and 15 to 900 arcs.
Fichier non déposé
hal-01105336 , version 1 (20-01-2015)
Nathalie Bostel, Philippe Castagliola, Pierre Dejax, André Langevin. Approximating the length of Chinese postman tours. 4OR: A Quarterly Journal of Operations Research, 2014, 12 (4), pp.359-372. ⟨10.1007/s10288-014-0260-9⟩. ⟨hal-01105336⟩
79 Consultations
0 Téléchargements
