Multilingual discriminative shift reduce phrase structure parsing for the SPMRL 2014 shared task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2014
This paper describes the design of a multilingual lexicalized discriminative shift reduce phrase structure based parser used to parse the SPMRL 2014 shared task data set. It reports the results of one of the first massively multilingual lexicalized phrase structure parser and shows that it behaves surprisingly well on a multilingual setting.
Fichier non déposé
hal-01105345 , version 1 (20-01-2015)
  • HAL Id : hal-01105345 , version 1
Benoît Crabbé, Djamé Seddah. Multilingual discriminative shift reduce phrase structure parsing for the SPMRL 2014 shared task. First Joint Workshop on Statistical Parsing of Morphologically Rich Languages and Syntactic Analysis of Non-Canonical Languages, 2014, Dublin, Ireland. 2014. ⟨hal-01105345⟩
65 Consultations
0 Téléchargements
