New interface
Reports (Research report)
Evaluation of Distributed Congestion Control -Reactive DCC
Abstract : Reactive Dynamic Distributed congestion control is an algorithm developed by the European Telecommunications Standards Institute as a solution to channel congestion issu in the IEEE 802.11p V2X system. In the literature, it is shown that reactive DCC algorithm produces unstable channel usage and can show poorer performance and that of non-DCC controlled system. In this report we show the impact of system synchronisation issue, that caused by the DCC based on measurements of channel-busyness ratio, and developed an asynchronous Reactive DCC mechanism that largely outperforms both the reactive DCC and non-DCC systems.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01107740
Contributor : Oyunchimeg Shagdar Connect in order to contact the contributor
Submitted on : Wednesday, January 21, 2015 - 2:47:06 PM
Last modification on : Wednesday, October 26, 2022 - 8:15:30 AM
Identifiers
  • HAL Id : hal-01107740, version 1
Collections
Citation
Oyunchimeg Shagdar. Evaluation of Distributed Congestion Control -Reactive DCC. [Research Report] Inria. 2014. ⟨hal-01107740⟩
Share
Metrics
Record views
255
Files downloads
93
