QuantifQuantile : an R package for performing quantile regression through optimal quantization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The R Journal Année : 2015
In quantile regression, various quantiles of a response variable Y are modelled as func- tions of covariates (rather than its mean). An important application is the construction of reference curves/surfaces and conditional prediction intervals for Y. Recently, a nonparametric quantile regression method based on the concept of optimal quantization was proposed. This method competes very well with k-nearest neighbor, kernel, and spline methods. In this paper, we describe an R package, called QuantifQuantile, that allows to perform quantization-based quantile regression. We describe the various functions of the package and provide examples.
revison_Rjournal.pdf (1.37 Mo) Télécharger le fichier
hal-01108505 , version 1 (22-01-2015)
hal-01108505 , version 2 (13-01-2016)
  • HAL Id : hal-01108505 , version 2
Isabelle Charlier, Davy Paindaveine, Jérôme Saracco. QuantifQuantile : an R package for performing quantile regression through optimal quantization. The R Journal, 2015. ⟨hal-01108505v2⟩
344 Consultations
399 Téléchargements
