Co-expression analysis of high-throughput transcriptome sequencing data with Poisson mixture models
In recent years, gene expression studies have increasingly made use of high-throughput sequencing technology. In turn, research concerning the appropriate statistical methods for the analysis of digital gene expression (DGE) has flourished, primarily in the context of normalization and differential analysis.[br/]
In this work, we focus on the question of clustering DGE profiles as a means to discover groups of co-expressed genes. We propose a Poisson mixture model using a rigorous framework for parameter estimation as well as the choice of the appropriate number of clusters. We illustrate co-expression analyses using our approach on two real RNA-seq datasets. A set of simulation studies also compares the performance of the proposed model with that of several related approaches developed to cluster RNA-seq or serial analysis of gene expression data.[br/]
The proposed method is implemented in the open-source R package HTSCluster, available on CRAN.
