Identifiability and observability of nonlinear time-delay system with unknown inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
Using the theory of non-commutative rings, the delay identification problem of nonlinear time-delay systems with unknown inputs is studied. Necessary and sufficient conditions are proposed to judge the identifiability of the delay, where two different cases are discussed for the dependent and independent outputs, respectively. After that, necessary and sufficient conditions are given to analyze the causal and non-causal observability for nonlinear time-delay systems with unknown inputs.
Automatique
zheng.pdf (137.12 Ko) Télécharger le fichier
hal-01109157 , version 1 (24-01-2015)
  • HAL Id : hal-01109157 , version 1
Gang Zheng, Jean-Pierre Richard. Identifiability and observability of nonlinear time-delay system with unknown inputs. Recent Results on Nonlinear Time Delayed Systems, Springer Verlag, 2015. ⟨hal-01109157⟩
180 Consultations
297 Téléchargements
