A tour of Machine Learning: an AI perspective - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue AI Communications Année : 2014
Machine Learning has been at the core of Artificial Intelligence since its inception. Many promises have been held, if one is to consider that Google is a living demonstration of AI. This paper presents a historical perspective on Machine Learning, describing how the emphasis was gradually shifted from logical to statis-tical induction, from induction to optimization, from the search of hypotheses to the search of representa-tions. The paper concludes with a discussion about the new frontier of Machine Learning.
AI_ML_v2.pdf (271.39 Ko) Télécharger le fichier
hal-01109768 , version 1 (26-01-2015)
Michèle Sebag. A tour of Machine Learning: an AI perspective. AI Communications, 2014, 27 (1), pp.11-23. ⟨10.3233/AIC-130580⟩. ⟨hal-01109768⟩
527 Consultations
3344 Téléchargements
