Modulus Fault Attacks against RSA-CRT Signatures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
RSA-CRT fault attacks have been an active research area since their discovery by Boneh, DeMillo and Lipton in 1997. We present alternative key-recovery attacks on RSA-CRT signatures: instead of targeting one of the sub-exponentiations in RSA-CRT, we inject faults into the public modulus before CRT interpolation, which makes a number of countermeasures against Boneh et al.’s attack ineffective. Our attacks are based on orthogonal lattice techniques and are very efficient in practice: depending on the fault model, between 5 to 45 faults suffice to recover the RSA factorization within a few seconds. Our simplest attack requires that the adversary knows the faulty moduli, but more sophisticated variants work even if the moduli are unknown, under reasonable fault models. All our attacks have been fully validated experimentally with fault-injection laser techniques.
hal-01109981 , version 1 (27-01-2015)
Eric Brier, David Naccache, Phong Q. Nguyen, Mehdi Tibouchi. Modulus Fault Attacks against RSA-CRT Signatures. CHES 2011 - 13th International Workshop Cryptographic Hardware and Embedded Systems, Sep 2011, Nara, Japan. pp.192-206, ⟨10.1007/978-3-642-23951-9_13⟩. ⟨hal-01109981⟩
166 Consultations
0 Téléchargements
