A Convergent Data Completion Algorithm Using Surface Integral Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems Année : 2015
We propose and analyze a data completion algorithm based on the representation of the solution in terms of surface integral operators to solve the Cauchy problem for the Helmholtz or the Laplace equations. The proposed method is non iterative and intrinsically handle the case of noisy and incompatible data. In order to cope with the ill-posedness of the problem, our formulation is compatible with standard regularization methods associated with linear ill posed inverse problems and leads to convergent scheme. We numerically validate our method with different synthetic examples using a Tikhonov regularization.
DataCompletion_YB_HH.pdf (527.9 Ko) Télécharger le fichier
hal-01110005 , version 1 (27-01-2015)
  • HAL Id : hal-01110005 , version 1
Yosra Boukari, Houssem Haddar. A Convergent Data Completion Algorithm Using Surface Integral Equations. Inverse Problems, 2015, pp.21. ⟨hal-01110005⟩
401 Consultations
359 Téléchargements
