Extreme density level set estimation for input--output functions via the adaptive splitting technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of computational science Année : 2015
In order to estimate the minimum volume set of a probability very close to zero, a plug-in estimator of density level set is built based on the adaptive splitting technique, a rare event dedicated probability technique. This algorithm is the main novelty of this paper. It is applied on the realistic estimation of a booster fallout zone.
Fichier non déposé
hal-01110391 , version 1 (28-01-2015)
Rudy Pastel, Jérôme Morio, François Le Gland. Extreme density level set estimation for input--output functions via the adaptive splitting technique. Journal of computational science, 2015, 6, pp.40--46. ⟨10.1016/j.jocs.2014.11.001⟩. ⟨hal-01110391⟩
218 Consultations
0 Téléchargements
