Structure-Aware Mesh Decimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2015
We present a novel approach for the decimation of trian-gle surface meshes. Our algorithm takes as input a triangle surface mesh and a set of planar proxies detected in a pre-processing analysis step, and structured via an adjacency graph. It then performs greedy mesh decimation through a series of edge collapse, designed to approximate the local mesh geometry as well as the geometry and structure of proxies. Such structure-preserving approach is well suited to planar abstraction, i.e., extreme decimation approxi-mating well the planar parts while filtering out the others. Our experiments on a variety of inputs illustrate the po-tential of our approach in terms of improved accuracy and preservation of structure.
structure (1).pdf (50.54 Mo) Télécharger le fichier
hal-01111203 , version 1 (30-01-2015)
  • HAL Id : hal-01111203 , version 1
David Salinas, Florent Lafarge, Pierre Alliez. Structure-Aware Mesh Decimation. Computer Graphics Forum, 2015, pp.20. ⟨hal-01111203⟩
1745 Consultations
3141 Téléchargements
