Characterizing polynomial time complexity of stream programs using interpretations - Archive ouverte HAL Access content directly
Journal Articles Theoretical Computer Science Year : 2015
(1) , (1) , (1) , (1)
1
This paper provides a criterion based on interpretation methods on term rewrite systems in order to characterize the polynomial time complexity of second order functionals. For that purpose it introduces a first order functional stream language that allows the programmer to implement second order functionals. This characterization is extended through the use of exp-poly interpretations as an attempt to capture the class of Basic Feasible Functionals (bff). Moreover, these results are adapted to provide a new characterization of polynomial time complexity in computable analysis. These characterizations give a new insight on the relations between the complexity of functional stream programs and the classes of functions computed by Oracle Turing Machine, where oracles are treated as inputs.
FEREE_HAINRY_HOYRUP_PECHOUX.pdf (374.77 Ko) Télécharger le fichier
Dates and versions
hal-01112160 , version 1 (02-02-2015)
Attribution - CC BY 4.0
Identifiers
Cite
Hugo Férée, Emmanuel Hainry, Mathieu Hoyrup, Romain Péchoux. Characterizing polynomial time complexity of stream programs using interpretations. Theoretical Computer Science, 2015, 585, pp.41-54. ⟨10.1016/j.tcs.2015.03.008⟩. ⟨hal-01112160⟩
414 View
164 Download
Share
