Numerical solution of the Optimal Transportation problem using the Monge–Ampère equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2014
A numerical method for the solution of the elliptic Monge–Ampère Partial Differential Equation, with boundary conditions corresponding to the Optimal Transportation (OT) problem, is presented. A local representation of the OT boundary conditions is combined with a finite difference scheme for the Monge–Ampère equation. Newtonʼs method is implemented, leading to a fast solver, comparable to solving the Laplace equation on the same grid several times. Theoretical justification for the method is given by a convergence proof in the companion paper [4]. Solutions are computed with densities supported on non-convex and disconnected domains. Computational examples demonstrate robust performance on singular solutions and fast computational times
hal-01115626 , version 1 (11-02-2015)
Jean-David Benamou, Brittany D. Froese, Adam M. Oberman. Numerical solution of the Optimal Transportation problem using the Monge–Ampère equation. Journal of Computational Physics, 2014, 260 (1), pp.107-126. ⟨10.1016/j.jcp.2013.12.015⟩. ⟨hal-01115626⟩
Collections
INRIA INRIA2
222 Consultations
0 Téléchargements
