Conference papers
Replication for send-deterministic MPI HPC applications
Abstract : Replication has recently gained attention in the context of fault tolerance for large scale MPI HPC applications. Existing implementations try to cover all MPI codes and to be independent from the underlying library. In this paper, we evaluate the advantages of adopting a different approach. First, we try to take advantage of a communication property common to many MPI HPC application, namely send-determinism. Second, we choose to implement replication inside the MPI library. The main advantage of our approach is simplicity. While being only a small patch to the Open MPI library, our solution called SDR-MPI supports most main features of the MPI standard including all collectives and group operations. SDR-MPI additionally achieves good performance: Experiments run with HPC benchmarks and applications show that its overhead remains below 5%.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01121949
Contributor : Thomas Ropars Connect in order to contact the contributor
Submitted on : Monday, March 2, 2015 - 10:07:26 PM
Last modification on : Saturday, September 11, 2021 - 3:17:41 AM
Long-term archiving on: : Tuesday, June 2, 2015 - 9:56:12 AM
File
ftxs06-lefray.pdf
Identifiers
Collections
Citation
Arnaud Lefray, Thomas Ropars, André Schiper. Replication for send-deterministic MPI HPC applications. 3rd Workshop on Fault-Tolerance for HPC at Extreme Scale (FTXS), 2013, New-York City, United States. ⟨10.1145/2465813.2465819⟩. ⟨hal-01121949⟩
Share
Metrics
Les métriques sont temporairement indisponibles
