Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Reports
Tighter Reductions for Forward-Secure Signature Schemes
Michel Abdalla 1, 2, 3 Fabrice Benhamouda 1, 3, 2 David Pointcheval 3, 1, 2
Abstract : In this paper, we revisit the security of factoring-based signature schemes built via the Fiat-Shamir transform and show that they can admit tighter reductions to certain decisional complexity assumptions such as the quadratic-residuosity, the high-residuosity, and the φ- hiding assumptions. We do so by proving that the underlying identification schemes used in these schemes are a particular case of the lossy identification notion recently introduced by Abdalla et al. at Eurocrypt 2012. Next, we show how to extend these results to the forward-security setting based on ideas from the Itkis-Reyzin forward-secure signature scheme. Unlike the original Itkis-Reyzin scheme, our construction can be instantiated under different decisional complexity assumptions and has a much tighter security reduction. Finally, we show that the tighter security reductions provided by our proof methodology can result in concrete efficiency gains in practice, both in the standard and forward-security setting, as long as the use of stronger security assumptions is deemed acceptable. All of our results hold in the random oracle model.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/hal-01132190
Contributor : Michel Abdalla Connect in order to contact the contributor
Submitted on : Monday, March 16, 2015 - 6:04:38 PM
Last modification on : Thursday, March 17, 2022 - 10:08:37 AM
Identifiers
  • HAL Id : hal-01132190, version 1
Collections
Citation
Michel Abdalla, Fabrice Benhamouda, David Pointcheval. Tighter Reductions for Forward-Secure Signature Schemes. [Technical Report] Cryptology ePrint Archive: Report 2015/196, IACR. 2015. ⟨hal-01132190⟩
Share
Metrics
Record views
111
