Hardware and Arithmetic for Hyperelliptic Curves Cryptography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2015
We present our first results on the extension of computation accelerators designed for Elliptic Curve Cryptography (ECC) to the case of Hyper-Elliptic Curve Cryptography (HECC). We will provide both arithmetic operators and computation architectures optimized for high speed, lost-cost implementation (silicon area and energy), and finally, protected crypto-processors against some Side Chanel Attacks (both passive and active ones).
poster.pdf (2.47 Mo) Télécharger le fichier
hal-01134020 , version 1 (29-03-2015)
  • HAL Id : hal-01134020 , version 1
Gabriel Gallin, Arnaud Tisserand, Nicolas Veyrat-Charvillon. Hardware and Arithmetic for Hyperelliptic Curves Cryptography. RAIM: 7ème Rencontre Arithmétique de l'Informatique Mathématique, Apr 2015, Rennes, France. , 2015. ⟨hal-01134020⟩
343 Consultations
179 Téléchargements
