Simulation Levels of Detail for Real-time Virtual Worlds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Bernard Valton
  • Fonction : Auteur
Bertrand Jouin
  • Fonction : Auteur
Rémi Cozot
Animating numerous human-like gures in large virtual spaces makes it diicult to provide users with an interactive simulation rate. The prob-lems mainly consist in the large numb e r o f w alk-ers required to simulate realistic virtual spaces and in the accuracy of the model needed to ac-count for complex environments. We propose a new approach of model design in order to mini-mize the computation cost according to the kind of simulation and environment. A l o w-cost sim-pliied walking model is designed for at ground while a more complex one is proposed for com-plex terrains. We also describe how and when the transitions between these models occur while ensuring a visually realistic motion. The re-sults show that using simulation levels of detail is specially suitable for simulations in large virtual spaces and makes it possible to visualize realistic motions of walkers with a controlled computation cost.
Fichier non déposé
hal-01142559 , version 1 (15-04-2015)
  • HAL Id : hal-01142559 , version 1
Franck Multon, Bernard Valton, Bertrand Jouin, Rémi Cozot. Simulation Levels of Detail for Real-time Virtual Worlds. ASTC-VR'99, 1999, San Diego, United States. ⟨hal-01142559⟩
226 Consultations
0 Téléchargements
