A Reconfigurable Component Model for HPC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
High-performance applications whose structure changes dynamically during execution are extremely complex to develop, maintain and adapt to new hardware. Such applications would greatly benefit from easy reuse and separation of concerns which are typical advantages of component models. Unfortunately, no existing component model is both HPC-ready (in terms of scalability and overhead) and able to easily handle dynamic reconfiguration. We aim at addressing performance, scalability and programmability by separating locking and synchronization concerns from reconfiguration code. To this end, we propose directMOD, a component model which provides on one hand a flexible mechanism to lock subassemblies with a very small overhead and high scalability, and on the other hand a set of well-defined mechanisms to easily plug various independently-written reconfiguration components to lockable subassemblies. We evaluate both the model itself and a C++/MPI implementation called directL2C .
Fichier non déposé
hal-01142606 , version 1 (15-04-2015)
  • HAL Id : hal-01142606 , version 1
Vincent Lanore, Christian Pérez. A Reconfigurable Component Model for HPC. CBSE 2015, May 2015, Montréal, Canada. pp.10. ⟨hal-01142606⟩
191 Consultations
0 Téléchargements
