Time-data tradeoff for the sparse and cosparse regularizations of physics-driven inverse problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2015
We investigate the computational performance of the sparse vs cosparse regularizations applied to physics-driven inverse problems, relative to the amount of measurements. Our results show that, despite nominal equivalence of the two models in the given context, the analysis-based optimization benefits from an increase in the volume of available data, while the synthesis one does not.
SPARS15.pdf (195.43 Ko) Télécharger le fichier
hal-01147438 , version 1 (30-04-2015)
hal-01147438 , version 2 (25-06-2015)
  • HAL Id : hal-01147438 , version 2
Srđan Kitić, Nancy Bertin, Rémi Gribonval. Time-data tradeoff for the sparse and cosparse regularizations of physics-driven inverse problems. SPARS15 - Signal Processing with Adaptive Sparse Structured Representations, Jul 2015, Cambridge, United Kingdom. ⟨hal-01147438v2⟩
350 Consultations
193 Téléchargements
