Certifying the interoperability of RDF database systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In March 2013, the W3C recommended SPARQL 1.1 to retrieve and manipulate decentralized RDF data. Real-world usage requires advanced features of SPARQL 1.1. recommendations As these are not consistently implemented, we propose a test framework named TFT (Tests for Triple stores) to test the interoperability of the SPARQL end-point of RDF database systems. This framework can execute the W3C's SPARQL 1.1 test suite and also its own tests of interoperability. To help the developers and end-users of RDF databases, we perform daily tests on Jena-Fuseki, Marmotta-KiWistore, 4Store and three other commercial databases. With these tests, we have built a scoring system named SPARQLScore and share our results on the website http://sparqlscore.com.
ESWC_LDQ2015_Certifying_the_interoperability_FINAL_VERSION.pdf (425.71 Ko) Télécharger le fichier
hal-01147765 , version 1 (01-05-2015)
Paternité - Pas de modifications
  • HAL Id : hal-01147765 , version 1
Karima Rafes, Julien Nauroy, Cécile Germain. Certifying the interoperability of RDF database systems. LDQ 2015 - 2nd Workshop on Linked Data Quality, May 2015, Portorož, Slovenia. ⟨hal-01147765⟩
3457 Consultations
215 Téléchargements
