Calcul de cliques maximales dans les flots de liens - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tiphaine Viard
Matthieu Latapy
Clémence Magnien
A link stream is a collection of triplets (t,u,v) indicating that an interaction occurred between u and v at time t. We generalize the classical notion of cliques in graphs to such link streams: for a given Δ, a Δ-clique is a set of nodes and a time interval such that all pairs of nodes in this set interact at least once during each sub-interval of duration Δ. We propose an algorithm to enumerate all maximal (in terms of nodes or time interval) cliques of a link stream, and illustrate its practical relevance on a real-world contact trace.
cliques-algotel.pdf (115.38 Ko) Télécharger le fichier
hal-01147966 , version 1 (04-05-2015)
hal-01147966 , version 2 (03-08-2016)
  • HAL Id : hal-01147966 , version 2
Tiphaine Viard, Matthieu Latapy, Clémence Magnien. Calcul de cliques maximales dans les flots de liens. 17èmes Rencontres Francophones sur les Aspects Algorithmiques des Télécommunications (AlgoTel 2015), Jun 2015, Beaune, France. ⟨hal-01147966v2⟩
322 Consultations
185 Téléchargements
