Journal articles
A Framework for Defining Logical Frameworks
Abstract : In this paper, we introduce a General Logical Framework, called GLF, for defining Logical Frameworks, based on dependent types, in the style of the well known Edinburgh Logical Framework LF. The framework GLF features a generalized form of lambda abstraction where β-reductions fire provided the argument satisfies a logical predicate and may produce an n-ary substitution. The type system keeps track of when reductions have yet to fire. The framework GLF subsumes, by simple instantiation, LF as well as a large class of generalized constrained-based lambda calculi, ranging from well known restricted lambda calculi, such as Plotkin's call-by-value lambda calculus, to lambda calculi with patterns. But it suggests also a wide spectrum of new calculi which have intriguing potential as Logical Frameworks. We investigate the metatheoretical properties of the calculus underpinning GLF and illustrate its expressive power. In particular, we focus on two interesting instantiations of GLF. The first is the Pattern Logical Framework (PLF), where applications fire via pattern-matching in the style of Cirstea, Kirchner, and Liquori. The second is the Closed Logical Framework (CLF) which features, besides standard β-reduction, also a reduction which fires only if the argument is a closed term. For both these instantiations of GLF we discuss standard metaproperties, such as subject reduction, confluence and strong normalization. The GLF framework is particularly suitable, as a metalanguage, for encoding rewriting logics and logical systems, where rules require proof terms to have special syntactic constraints, e.g. logics with rules of proof, in addition to rules of derivations, such as, e.g., modal logic, and call-by-value lambda calculus.
Complete list of metadata
Cited literature [36 references]  Display  Hide  Download
https://hal.inria.fr/hal-01148312
Contributor : Luigi Liquori Connect in order to contact the contributor
Submitted on : Monday, May 4, 2015 - 1:40:06 PM
Last modification on : Tuesday, October 26, 2021 - 4:27:42 PM
Long-term archiving on: : Wednesday, April 19, 2017 - 2:21:11 PM
File
2007-entcs-plotkin-06.pdf
Identifiers
Collections
Citation
Furio Honsell, Marina Lenisa, Luigi Liquori. A Framework for Defining Logical Frameworks. Electronic Notes in Theoretical Computer Science, Elsevier, 2007, In Computation, Meaning and Logic. ENTCS, Special issue, dedicated to Gordon D. Plotkin, on the occasion of his 60th birthday, 172, pp.399-436. ⟨10.1016/j.entcs.2007.02.014⟩. ⟨hal-01148312⟩
Share
Metrics
Les métriques sont temporairement indisponibles
