The Rho Cube - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
The Rho Cube
The rewriting calculus, or Rho Calculus, is a simple calculus that uniformly integrates abstraction on patterns and non-determinism. Therefore, it fully integrates rewriting and lambda-calculus. The original presentation of the calculus was untyped. In this paper we present a uniform way to decorate the terms of the calculus with types. This gives raise to a new presentation a la Church, together with nine (8+1) type systems which can be placed in a rho-cube that extends the lambda-cube of Barendregt. Due to the matching capabilities of the calculus, the type systems use only one abstraction mechanism and therefore gives an original answer to the identification of the standard ``lambda'' and ``Pi'' abstractors. As a consequence, this brings matching and rewriting as the first class concepts of the Rho-versions of the Logical Framework (LF) of Harper-Honsell-Plotkin, and of the Calculus of Constructions (CC) of Coquand-Huet.
A01-R-202.pdf (300.59 Ko) Télécharger le fichier
inria-00107877 , version 1 (19-10-2006)
Horatiu Cirstea, Claude Kirchner, Luigi Liquori. The Rho Cube. 4th International Conference on Foundations of Software Science and Computation Structures - FOSSACS 2001, Apr 2001, Genova, Italy. 15 p, ⟨10.1007/3-540-45315-6_11⟩. ⟨inria-00107877⟩
Relations
238 Consultations
126 Téléchargements
