New interface
Conference papers
Deformable Registration of Feature-Endowed Point Sets Based on Tensor Fields
Abstract : The main contribution of this work is a framework to register anatomical structures characterized as a point set where each point has an associated symmetric matrix. These matrices can represent problem-dependent characteristics of the registered structure. For example, in airways, matrices can represent the orientation and thickness of the structure. Our framework relies on a dense tensor field representation which we implement sparsely as a kernel mixture of tensor fields. We equip the space of tensor fields with a norm that serves as a similarity measure. To calculate the optimal transformation between two structures we minimize this measure using an analytical gradient for the similarity measure and the deformation field, which we restrict to be a diffeomorphism. We illustrate the value of our tensor field model by comparing our results with scalar and vector field based models. Finally, we evaluate our registration algorithm on synthetic data sets and validate our approach on manually annotated airway trees.
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01153110
Contributor : Demian Wassermann Connect in order to contact the contributor
Submitted on : Monday, February 17, 2020 - 1:00:41 PM
Last modification on : Friday, November 18, 2022 - 9:25:02 AM
Long-term archiving on: : Monday, May 18, 2020 - 3:43:06 PM
File
Wassermann_Deformable_Registra...
Identifiers
Collections
Citation
Demian Wassermann, James Ross, George Washko, William M Wells, Raul San Jose-Estepar. Deformable Registration of Feature-Endowed Point Sets Based on Tensor Fields. Computer Vision and Pattern Recognition, IEEE, Jun 2014, Columbus, Ohio, United States. pp.2729-2735, ⟨10.1109/CVPR.2014.355⟩. ⟨hal-01153110⟩
Share
Metrics
Record views
87
Files downloads
26
