Abstract : This paper proposes two novel and practical designs of angle diversity receivers to achieve multiple-input-multiple-output (MIMO) capacity for indoor visible light communications (VLC). Both designs are easy to be constructed and suitable for small mobile devices. By using light emitting diodes for both illumination and data transmission, our receiver designs consist of multiple photodetectors (PDs) which are oriented with different inclination angles to achieve high-rank MIMO channels and can be closely packed without the requirement of spatial separation. Due to the orientations of the PDs, the proposed receiver designs are named pyramid receiver (PR) and hemispheric receiver (HR). In a PR, the normal vectors of PDs are chosen the same as the normal vectors of the triangle faces of a pyramid with equilateral N-gon base. On the other hand, the idea of HR is to evenly distribute the PDs on a hemisphere. Through analytical investigation, simulations and experiments, the channel capacity and bit-error-rate (BER) performance under various settings are presented to show that our receiver designs are practical and promising for enabling VLC-MIMO. In comparison to induced link-blocked receiver, our designs do not require any hardware adjustment at the receiver from location to location so that they can support user mobility. Besides, their channel capacities and BER performance are quite close to that of link-blocked receiver. Meanwhile, they substantially outperform spatially-separated receiver. This study reveals that using angle diversity to build VLC-MIMO system is very promising.
