Abstract : Computing Delaunay triangulations in Rd
involves evaluating the so-called in\_sphere predicate that
determines if a point x lies inside, on or outside the sphere
circumscribing d+1 points p0,...,pd. This predicate reduces to evaluating the
sign of a multivariate polynomial of degree d+2in the coordinates
of the points x, p0,... pd. Despite much progress on exact
geometric computing, the fact that the degree of the polynomial
increases with d makes the evaluation of the sign of such a polynomial
problematic except in very low dimensions. In this paper, we propose a
new approach that is based on the witness complex, a
weak form of the Delaunay complex introduced by Carlsson and de
Silva.
The witness
complex wit (L,W) is defined from two sets L and W in some
metric space X: a finite set of points L on which the complex
is built, and a set W of witnesses that serves as an approximation
of X. A fundamental result of de Silva states that wit (L,W)= del (L) if W=X=Rd. In this paper, we give conditions on
L that ensure that the witness complex and the Delaunay
triangulation coincide when W is a finite set, and we
introduce a new perturbation scheme to compute a perturbed set L'
close to L such that del (L')= wit (L', W). Our perturbation algorithm is a geometric application of the Moser-Tardos
constructive proof of the Lovàsz local lemma.
The only numerical operations we use are (squared)
distance comparisons (i.e., predicates of degree 2). The
time-complexity of the algorithm is sublinear in |W|. Interestingly, although the algorithm does not
compute any measure of simplex quality, a lower bound on the
thickness of the output simplices can be guaranteed.
