Abstract : We investigate a first-order extension of the Theory of Primitive Objects of [5] that supports method extension in presence of object subsumption. Extension is the ability of modifying the behavior of an object by adding new methods (and inheriting the existing ones). Object subsumption allows to use objects with a bigger interface in a context expecting another object with a smaller interface. This extended calculus has a sound type system which allows static detection of run-time errors such as message-not-understood, " width " subtyping and a typed equational theory on objects. Moreover, it can express classes and class-inheritance.
https://hal.inria.fr/hal-01154568
Contributeur : Luigi Liquori
Soumis le : vendredi 22 mai 2015 - 14:05:26
Dernière modification le : samedi 27 janvier 2018 - 01:31:31
Document(s) archivé(s) le : jeudi 20 avril 2017 - 07:00:18
Luigi Liquori. An extended Theory of Primitive Objects: First order system. ECOOP, Jun 1997, Jyvaskyla, Finland. Springer Verlag, 1241, pp.146-169, 1997, Lecture Notes in Computer Science. 〈10.1007/BFb0053378〉. 〈hal-01154568〉
