Exploring the Geography of Tags in Youtube Views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
Although tags play a critical role in many social media, their link to the geographic distribution of user generated videos has been little investigated. In this paper, we ana- lyze the correlation between the geographic distribution of a video’s views and the tags attached to this video in a Youtube dataset. We show that tags can be interpreted as markers of a video’s geographic diffusion, with some tags strongly linked to well identified geographic areas. Based on our findings, we explore whether the distribution of a video’s views can be predicted from its tags. We demon- strate how this predictive power could help improve on-line video services by preferentially storing videos close to where they are likely to be viewed. Our results show that even with a simplistic approach we are able to predict a minimum of 65.9% of a video’s views for a majority of videos, and that a tag-based placement strategy can improve the hit rate of a distributed on-line video service by up to 6.8% globally, with an improvement of up to 34% in the USA.
RT-461.pdf (2.16 Mo) Télécharger le fichier
hal-01157867 , version 1 (28-05-2015)
Paternité - Pas d'utilisation commerciale
  • HAL Id : hal-01157867 , version 1
Stéphane Delbruel, Davide Frey, François Taïani. Exploring the Geography of Tags in Youtube Views. [Research Report] RT-0461, IRISA, Inria Rennes; INRIA. 2015, 27 p. ⟨hal-01157867⟩
937 Consultations
663 Téléchargements
