Robust Stabilization of MIMO Systems in Finite/Fixed Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2015
SUMMARY The control design problem for finite-time and fixed-time stabilization of linear multi-input system with nonlinear uncertainties and disturbances is considered. The control design algorithm based on block decomposition and Implicit Lyapunov Function (ILF) technique is developed. The robustness properties of the obtained control laws with respect to matched and unmatched uncertainties and disturbances are studied. Procedures for tuning of control parameters are presented in the form of Linear Matrix Inequalities (LMI). Aspects of practical implementation of developed algorithms are discussed. Theoretical results are supported by numerical simulations.
Automatique
main.pdf (708 Ko) Télécharger le fichier
MIMO.pdf (730.89 Ko) Télécharger le fichier
hal-01160052 , version 1 (04-06-2015)
Andrey Polyakov, Denis Efimov, Wilfrid Perruquetti. Robust Stabilization of MIMO Systems in Finite/Fixed Time. International Journal of Robust and Nonlinear Control, 2015, pp.23. ⟨10.1002/rnc⟩. ⟨hal-01160052⟩
167 Consultations
1229 Téléchargements
