A Computational Framework for Vertical Video Editing
Vertical video editing is the process of digitally editing the image within the frame as opposed to horizontal video editing, which arranges the shots along a timeline. Vertical editing can be a time-consuming and error-prone process when using manual key-framing and simple interpolation. In this paper, we present a general framework for automatically computing a variety of cinematically plausible shots from a single input video suitable to the special case of live performances. Drawing on working practices in traditional cinematography, the system acts as a virtual camera assistant to the film editor, who can call novel shots in the edit room with a combination of high-level instructions and manually selected keyframes.
vertical-editing-wiced15.pdf (2.35 Mo)
Télécharger le fichier
