Model-Based Identification of Anatomical Boundary Conditions in Living Tissues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a novel method dealing with the identification of boundary conditions of a deformable organ, a particularly important step for the creation of patient-specific biomechani-cal models of the anatomy. As an input, the method requires a set of scans acquired in different body positions. Using constraint-based finite element simulation, the method registers the two data sets by solving an optimization problem minimizing the energy of the deformable body while satisfying the constraints located on the surface of the registered organ. Once the equilibrium of the simulation is attained (i.e. the organ registration is computed), the surface forces needed to satisfy the constraints provide a reliable estimation of location, direction and magnitude of boundary conditions applied to the object in the deformed position. The method is evaluated on two abdominal CT scans of a pig acquired in flank and supine positions. We demonstrate that while computing a physically admissible registration of the liver, the resulting constraint forces applied to the surface of the liver strongly correlate with the location of the anatomical boundary conditions (such as contacts with bones and other organs) that are visually identified in the CT images.
Peterlik_PDFProof.pdf (3.12 Mo) Télécharger le fichier
Format : Figure, Image
hal-01264434 , version 1 (29-01-2016)
Igor Peterlik, Hadrien Courtecuisse, Christian Duriez, Stéphane Cotin. Model-Based Identification of Anatomical Boundary Conditions in Living Tissues. IPCAI 2014 - 5th International Conference on Information Processing in Computer Assisted Interventions, Jun 2014, Fukuoka, Japan. ⟨10.1007/978-3-319-07521-1_21⟩. ⟨hal-01264434⟩
473 Consultations
414 Téléchargements
