Efficient gene tree correction guided by genome evolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS ONE Année : 2016
Gene trees inferred solely from multiple alignments of homologous sequences often contain weakly supported and uncertain branches. Information for their full resolution may lie in the dependency between gene families and their genomic context. Integrative methods, using species tree information in addition to sequence information, have therefore been developed. They often rely on a computationally intensive tree space search which forecloses an application to large genomic databases. We propose a new method, called ProfileNJ, that takes a gene tree with statistical supports on its branches, and corrects its weakly supported parts by using a combination of information from a species tree and a distance matrix. Its low running time enabled us to use it on the whole Ensembl Compara database, for which we propose an alternative, arguably more plausible set of gene trees. This allowed us to perform a genome-wide analysis of duplication and loss patterns on the history of 63 eukaryote species, and predict ancestral gene content and order for all ancestors along the phylogeny.
journal.pone.0159559.PDF (3.37 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-01162963 , version 1 (11-06-2015)
hal-01162963 , version 2 (21-08-2015)
hal-01162963 , version 3 (09-04-2016)
hal-01162963 , version 4 (17-08-2016)
Emmanuel Noutahi, Magali Semeria, Manuel Lafond, Jonathan Seguin, Bastien Boussau, et al.. Efficient gene tree correction guided by genome evolution. PLoS ONE, 2016, 11 (8), e0159559 (22 p.). ⟨10.1371/journal.pone.0159559⟩. ⟨hal-01162963v4⟩
536 Consultations
566 Téléchargements
