Augmented letters: mnemonic gesture-based shortcuts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yves Guiard
Éric Lecolinet
James Eagan
We propose Augmented Letters, a new technique aimed at augmenting gesture-based techniques such as Marking Menus [9] by giving them natural, mnemonic associations. Augmented Letters gestures consist of the initial of command names, sketched by hand in the Unistroke style, and affixed with a straight tail. We designed a tentative touch device interaction technique that supports fast interactions with large sets of commands, is easily discoverable, improves user's recall at no speed cost, and supports fluid transition from novice to expert mode. An experiment suggests that Augmented Letters outperform Marking Menu in terms of user recall.
aletters-author-version.pdf (349.87 Ko) Télécharger le fichier
ALVideo.mp4 (9.15 Mo) Télécharger le fichier
hal-01164207 , version 1 (16-06-2015)
Quentin Roy, Sylvain Malacria, Yves Guiard, Éric Lecolinet, James Eagan. Augmented letters: mnemonic gesture-based shortcuts. Proceedings of the SIGCHI Conference on Human Factors in Computing Systems, Apr 2013, Paris, France. ⟨10.1145/2470654.2481321⟩. ⟨hal-01164207⟩
123 Consultations
224 Téléchargements
