Highly Expressive Query Languages for Unordered Data Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theory of Computing Systems Année : 2015
We study highly expressive query languages for unordered data trees, using as formal vehicles Active XML and extensions of languages in the while family. All languages may be seen as adding some form of control on top of a set of basic pattern queries. The results highlight the impact and interplay of different factors: the expressive power of basic queries, the embedding of computation into data (as in Active XML), and the use of deterministic vs. nondeterministic control. All languages are Turing complete, but not necessarily query complete in the sense of Chandra and Harel. Indeed, we show that some combinations of features yield serious limitations, analogous to FO-k definability in the relational context. On the other hand, the limitations come with benefits such as the existence of powerful normal forms providing opportunities for optimization. Other languages are ``almost'' complete, but fall short because of subtle limitations reminiscent of the copy elimination problem in object databases.
journal.pdf (488.03 Ko) Télécharger le fichier
hal-01167068 , version 1 (24-06-2015)
Serge Abiteboul, Pierre Bourhis, Victor Vianu. Highly Expressive Query Languages for Unordered Data Trees. Theory of Computing Systems, 2015, 57, pp.927-966. ⟨10.1007/s00224-015-9617-5⟩. ⟨hal-01167068⟩
222 Consultations
91 Téléchargements
