Abstract : Draco [Kazi et al. 2014] is a sketch-based interface that allows artists and casual users alike to add a rich set of animation effects to their drawings, seemingly bringing illustrations to life. While previous systems have introduced sketch-based animations for individual objects, our contribution is a unified framework of motion controls that allows users to seamlessly add coordinated motions to object collections. From an interface design perspective, the key challenge to this problem is to formulate a general framework for workflow and controls that is easy to use, but expressive enough to author a wide range of dynamic phenomena.
