Formal Verification of Programs Computing the Floating-Point Average - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The most well-known feature of floating-point arithmetic is the limited precision, which creates round-off errors and inaccuracies. Another important issue is the limited range, which creates underflow and overflow, even if this topic is dismissed most of the time. This article shows a very simple example: the average of two floating-point numbers. As we want to take exceptional behaviors into account, we cannot use the naive formula (x+y)/2. Based on hints given by Sterbenz, we first write an accurate program and formally prove its properties. An interesting fact is that Sterbenz did not give this program, but only specified it. We prove this specification and include a new property: a precise certified error bound. We also present and formally prove a new algorithm that computes the correct rounding of the average of two floating-point numbers. It is more accurate than the previous one and is correct whatever the inputs.
article.pdf (342.49 Ko) Télécharger le fichier
hal-01174892 , version 1 (10-07-2015)
  • HAL Id : hal-01174892 , version 1
Sylvie Boldo. Formal Verification of Programs Computing the Floating-Point Average. 17th International Conference on Formal Engineering Methods, Nov 2015, Paris, France. pp.17-32. ⟨hal-01174892⟩
416 Consultations
710 Téléchargements
