Improved Partition Trees for Multi-Class Segmentation of Remote Sensing Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new binary partition tree (BPT)-based framework for multi-class segmentation of remote sensing images. In the literature, BPTs are typically computed in a bottom-up manner based on spectral similarities, then analyzed to extract image objects. When image objects exhibit a considerable internal spectral variability, it often happens that such objects are composed of several disjoint regions in the BPT, yielding errors in object extraction. We pose the multi-class segmentation problem as an energy minimization task and solve it by using BPTs. Our main contribution consists in introducing a new dissimilarity function for the tree construction , which combines both spectral discrepancies and supervised class-specific information to take into account the within-class spectral variability. The experimental validation proved that the proposed method constitutes a competitive alternative for object-based image classification.
IGARSS2015_Maggiori.pdf (2.99 Mo) Télécharger le fichier
hal-01182772 , version 1 (03-08-2015)
  • HAL Id : hal-01182772 , version 1
Emmanuel Maggiori, Yuliya Tarabalka, Guillaume Charpiat. Improved Partition Trees for Multi-Class Segmentation of Remote Sensing Images. 2015 IEEE International Geoscience and Remote Sensing Symposium - IGARSS 2015, IEEE, Jul 2015, Milan, Italy. ⟨hal-01182772⟩
482 Consultations
222 Téléchargements
