TTC'2015 Case: Refactoring Java Programs using Spoon
TTC'2015 is the 8th Transformation Tool Contest for users and developers of transformation tools. In this paper, we present the use of Spoon, an open-source library to transform and analyze Java source code for the code refactoring track of TTC'2015. We use Spoon to implement pull-up-method and create super-class refactorings. The implementation uses an unmodified revision of Spoon and is done in 125 lines.
Génie logiciel [cs.SE]
