New interface
Journal articles
Mercury: Properties and Design of a Remote Debugging Solution using Reflection
Nick Papoulias 1 Noury Bouraqadi 2 Luc Fabresse 2 Stéphane Ducasse 1 Marcus Denker 1
1 RMOD - Analyses and Languages Constructs for Object-Oriented Application Evolution
Inria Lille - Nord Europe, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : Remote debugging facilities are a technical necessity for devices that lack appropriate input/output interfaces (display, keyboard, mouse) for programming (e.g., smartphones, mobile robots) or are simply unreachable for local development (e.g., cloud-servers). Yet remote debugging solutions can prove awkward to use due to re-deployments. Empirical studies show us that on average 10.5 minutes per coding hour (over five 40-hour work weeks per year) are spent for redeploying applications (including re-deployments during debugging). Moreover current solutions lack facilities that would otherwise be available in a local setting because it is difficult to reproduce them remotely. Our work identifies three desirable properties that a remote debugging solution should exhibit, namely: run-time evolution, semantic instrumentation and adaptable distribution. Given these properties we propose and validate Mercury, a remote debugging model based on reflection. Mercury supports run-time evolution through a causally connected remote meta-level, semantic instrumentation through the reification of the underlying execution environment and adaptable distribution through a modular architecture of the debugging middleware.
Document type :
Journal articles
Complete list of metadata
Cited literature [58 references]  Display  Hide  Download
https://hal.inria.fr/hal-01185730
Contributor : Lse Lse Connect in order to contact the contributor
Submitted on : Friday, August 21, 2015 - 12:55:26 PM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Wednesday, April 26, 2017 - 10:20:38 AM
File
Papo15b-Mercury-JOT.pdf
Identifiers
Citation
Nick Papoulias, Noury Bouraqadi, Luc Fabresse, Stéphane Ducasse, Marcus Denker. Mercury: Properties and Design of a Remote Debugging Solution using Reflection. The Journal of Object Technology, 2015, 14 (2), pp.36. ⟨10.5381/jot.2015.14.2.a1⟩. ⟨hal-01185730⟩
Share
Metrics
Record views
400
Files downloads
224
